Results 1 to 2 of 2
    Hooligan Max Seat Height
    I am wondering if anyone can tell me the maximum seat height on a cannondale hooligan. I am 6'4" with a 34" inseam so longer in the upper body but just wondering if I will be able to raise the seat high enough to get the proper leg extension?
    thanks
    The post is 520mm and the minimum insertion depth is either 80 or 100mm. So if you look at the geometry of the Hooligan and crunch some numbers you should be able to get an idea if it's something that is going to work for you.
