Results 1 to 3 of 3
    Help required with Lefty Speed Carbon SL removal
    I need to replace the headseat bearings on my Taurine so need to dismount by Si Stem Steerer and Lefty Carbon fork? I have read the manual which seems to require a special tool (KT021?) which I can't source in the UK. Does anyone know a workaround method that doesn't require this tool?
    While I,m here, does anyone know the headset bearing dims/type if I struggle to get the original Cannondale parts.
    Also looking to replace th seat post binder/clamp with something a bit lighter than the stock item. Does anyone know if a KCNC Road Lite or SC11 34.9mm will work. Both have a slighty offset opening and I am not sure if this will work with the plastic shim thing?
    Tool
    Reputation: Pedalphile's Avatar
    This thread has some options for a headset removal tool.
    -Pete
    I can barely get my mouth around it.
    Pete,
    Great thread. I have a D Cell Maglite and a load of 1.5" pipe so should be a breeze.
    I've made a bit of mess of the XC3 bottom cap. Does anyone know is these are available as a part on it's own?
