Results 1 to 3 of 3
    Help with Old Cannondale Hardtail.....
    I have an f900sx cannondale hardtail from the early 90s; it has a lefty fork. Can anybody tell me if there is an option out there to put a rigid fork on the front? The headtube is pretty large so I don't know if it is an option.
    I am trying to make a training bike out of it so I don't put miles on my full suspension bike.
    I also need to figure out what kind of bottom bracket it has to fix. It has old CODA parts, which are horrible. I have to replace the disk brakes too, they are Coda and have a much narrower clamp than modern brakes.
    Any help/suggestions?
    Thanks.
    bikeaholic
    ^^^ That's a good option, but you would still need a new 1.125" headset in addition to the cups.
    The headtube on your bike is is 1.5" in diameter, so all that you need is a 1.5" to 1.125" reducer headset and you can put any standard-sized fork on there.
    I have this headset on my Jekyll to fit my Manitou 1.125" steer tube fork:
    http://www.universalcycles.com/shopp...4&category=724
    Of course, if you can find a rigid fork with a 1.5" steer tube, then you don't need anything extra, just swap the forks. I'm not sure if one of those exists though.
