Results 1 to 6 of 6
    edj
    edj is offline
    HELP NEEDED Removing Lefty from Flash 29er
    I'm trying to remove the lefty from my Flash 29er 2 to send it off to Craig at Mendon for servicing. I'm following the clear instructions on this link Lefty Stem/Steerer Removal BUT I don't have the Canondale tool. I'm using a piece of wood to tap out the steering tube and this worked fine up until the last bit, which won't come out. Not sure if I should tap harder or what.
    Photo of progress attached.
    Unfortunately Mendon is closed today so I couldn't ask Craig. Hope somebody else knows the answer so I can finish this up today. THANKS!
    Attached Thumbnails Attached Thumbnails HELP NEEDED Removing Lefty from Flash 29er-3040693140735_orig.jpeg
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    put the one piece in vertical position, not like in picture
    unscrew a little bit more the lefty upper clamp bolt
    use a Maglite lamp
    use the handle of a rubber hammer
    Feb 2005
    Yep, make sure it's vertical, not tweaked as shown in the pic, this may be tough due to cable housings etc so do what you can to help that so you don't yank them in a funky way.
    You're running into the lower bearing seat. It's getting stuck (as it should) on the upper bearing. A few more whacks and out it should come.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Removing the handlebars might make it easier to straighten it up. I've removed mine several times without the Cannondale tool by just using a wooden rod and hammer.
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
    edj
    edj is offline
    Thanks for tips. Ran out of time and will finish up or take it to LBS next week when I get back from trip.
    Awesome, you have the same bike I do! I love that green!
    I did the same thing to lube/overhaul my headset. Straighten it out a tad and give a few more good taps with a wooden dowel. I actually have a common hammer that has a handle diameter that is just the perfect size for this job.
    Don't be too afraid to give it another few good whacks once you straighten it out. I'm rather ham-fisted and still made a smooth job of the whole procedure.
  1. 29er Throwdown: Flash Alloy vs. Flash Carbon
    By brentos in forum Cannondale
    Last Post: 09-16-2012, 11:36 AM
  2. Replies: 0
    Last Post: 07-21-2011, 05:59 AM
  3. Flash 29er, Lefty questions
    By pulser in forum Cannondale
    Last Post: 05-08-2011, 03:57 PM
  4. Difference between 2011 Flash 29er 2+3 lefty
    By uwprunner in forum Cannondale
    Last Post: 10-22-2010, 09:26 AM
  5. Lefty Question (FLASH 29er Carbon)
    By mw29er in forum Cannondale
    Last Post: 06-25-2010, 06:42 PM
