Results 1 to 32 of 32
    breathing helium
    Reputation: cocheese's Avatar
    help me make sense of XLR & PBR Lefty choice
    I am expecting a 29er with Lefty soon. I have the choice of the 2011 PBR or XLR 29er. I have read the literature, but can some of you Lefty experts explain this to me in simple terms?
    I am going to be riding mostly cross country and doing some endurance racing with it. The frame will be Ti and will be run with the 321 type headtube adapter.
    Thanks for the help!
    YB1
    YB1 is offline
    One Euro catalog I saw made it look like 29'er Lefties this year come in 4 flavors, two carbon and two alloy. You can get XLR which is bar mounted remote lockout or PBR which stands for Push Button Release.
    Emory Kalahari Kruiser
    breathing helium
    So, outside of the location of the lock out mechanism, they are essentially identical?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    A bit of not too technically deep info can be found here. The PBR is a bit lighter too since it doesn't have the remote, the hose and additional fluid.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    The only difference between the PBR and XLR is the remote. You can actually retro-fit the XLR remote to an existing PBR.
    Aug 2010
    Quote Originally Posted by wv_rider
    OK, so what's the difference between DLR & PBR then?
    Andy
    LA CHÈVRE
    Different damping charateristics, the DLR has a lever lock-out that turns, with no blow-off, when you lock it, it will stay locked no matter what until you turn the lever back. The PBR has a button you press to lock it. The PBR and XLR have a blow off meaning that when locked, if you hit a big enough bump or drop, it will unlock. The blow-off point are adjustable internally. I think it's a good idea as you don't have to think about unlocking it and it helps protects the seals that, on the DLR, take a lot of pressure when you hit things with the lock-out on, do that too often and the seals will eventually fail and need to be replaced...
    Reputation: nathanbal's Avatar
    i havent seen a definitive answer yet... but are the xlr or pbr mechanism able to be retrofitted to a 110mm carbon sl dlr2?
    You will be able to put a complete XLR or PBR damper into the 110mm Carbon SL DLR2. The thing is that the new dampers are 100mm.
    Aug 2010
    Do you have a reference for any of this? Lock-out with blow-off would be a desirable retrofit for my Lefty Speed (alloy) & I don't see 10mm as a drastic difference, tbh.
    Andy
    yes, the interface is the same...the new dampers will fit into previous year SL structures so I've been told.
    Dec 2008
    Quote Originally Posted by Dan Gerous
    Does this apply to the 2010 PBR (I have a Max Carbon 140)?
    Reputation: DrewBird's Avatar
    I was wondering about this as well; the Flash 29er 2 that I have my eye on has PBR, but I'd really like a bar-mounted lockout. So is it the case that I can buy the XLR lockout kit after-market and retrofit to a PBR Lefty?
    LA CHÈVRE
    Quote Originally Posted by Crossmaxx
    As far as I know, yes, it's adjustable but I would double-check, I haven't played much with that Lefty model.
    breathing helium
    Thanks for the help everyone. I chose the 2011 Speed Carbon 29er XLR.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by cocheese
    I rode one in July and it was awesome! Very solid lockout and the lever/button has a very good feel.
    A related question, is the PBR basically an in house version of the Fox RLC system for lock out force adjustment, if a bit less adjustable?
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    Quote Originally Posted by amillmtb
    By SOLID, do you mean very rigid when locked out like leftys of old?
    I am wondering if the 2011 leftys are as rigid when locked out as my 2007/2008 models. I know there is a blowoff valve now, but my question is if the blowoff is not engaged is there any give like the Fox forks.
    Reputation: karlmichael's Avatar
    My 2010 lefty max is back at cannondale for some warrenty work due to a top out feeling with every cycling of the shock . Does cannondale instal the lock out hard ware or does your lbs? Will this kit work with the 2010 pbr? Also if I just deside to keep the pbr set up can it be made to require more force to activate the shock? Thanks
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    here pics
    Attached Thumbnails Attached Thumbnails help me make sense of XLR & PBR Lefty choice-hpim0980.jpg
    FIRENZE rulez !!
    Quote Originally Posted by yogiprophet
    sleep safe .
    when locked , it has the same stiffness all we know .
    Quote Originally Posted by eliflap
    here pics
    Thanks Eli,
    Can the remote be used on the right side?
    The stock lever is left side only. Sram does make a right side version if needed.
    LA CHÈVRE
    Note that there is a Cannondale specific Xloc lever in the works, since the floodgate knob is not functional when used on the Lefty XLR, they are working on a simpler, lighter lever... Don't wait for it though.
    Jun 2010
    Has anyone seen manuals for 2011 lefties so far? i'm interested in speeds ))
    Feb 2010
    XLR is worth it for the lockout on the bar , no fumbling around as you tear down a trail.
    The floodgate knob worked on the Flash 29er I rode. It is a compression damping adjuster. I have been waiting for Cdale to put a compression adjuster on the Lefty for a long time. It is sweeeeeet!
    Cannondale says that the floodgate is not adjustable. It is only used by them to ensure that the bleed in the system is correct. If you turn the knob, the only thing that you can do is make the lockout not work.
    Really!!?? Cannondale said that?
    I promise you I wasn't high when I rode the new 29er. And Yes, it definitely made a big difference in the compression. I could adjust it from almost no damping to super slow - almost locked out. I thought it was a great feature. If you can get to Bike-N-Sport in Santa Fe, give it a try.
    Reputation: Spinning Lizard's Avatar
    Have mine on the right, no problem - stock XLR on a 2011 Flash 29er 1
    csh
    csh is offline
    Double post.
    Old School
    Reputation: bourne4red's Avatar
    Oct 2010
    Can I fit the blowback/Xloc to my 2010 Speed Carbon DLR?
Members who have read this thread: 12
