Results 1 to 5 of 5
    HELP: How do I change the battery for Airspeed Dual Pump?
    Hi, just received an Airspeed Dual Pump without any instructions. How do I change the battery? The pump itself is very good and the digital pressure gauge is useful.
    Many thanks
    Figured it out, you have to gently slide a cover away to expose the battery.
    where did you find one? cannondale told me they were out till late march/april
    I have been given a sample from a retailer. I asked for one and they indeed said April, however the lady in the shop said 'I will see if I can get you one' and hey presto. My only gripe with the pump is the plastic mounting around the screw holes could have been better and the price. Great pump though...
    Just to let you all know that I have tried the pump on my headshock today and it basically doesn't work. The air just comes straight out of the bleeder valve, also it has difficulty pumping tyres up to racing pressures. I am going to write to place where I purchased it from and find out if this down to having a prototype model.
