Results 1 to 2 of 2
    Reputation: dynamic213's Avatar
    Nov 2007
    Help with bottom bracket
    I have a CAAD4 frame and was wondering what type and size bottom brackets are compatible with it? I'm thinking about replacing the entire coda crank/bb with something better.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The BB is a 68 x 113 I think. The type you had doesn't matter much if you change the BB and crankset. Outboard bearing style cranks have a fixed width, you just add spacers to fit the different frame setups.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
