Results 1 to 6 of 6
    Headshok folks, which pump do you use?
    a google search shows a ton of manufacturers for fork pumps. I just want to make sure they will work for my Fatty DLR. Which ones do you guys use?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I have used Fox, Wrench Force (Trek), Manitou and others. The Manitou works the worst, the end knob you screw onto the valve is a bit tight and even worse when screwed, it turns with the tube so when connecting or disconnecting, the whole pump has to be turned which makes it harder to take off quickly. The others work fine and normally, all recent shock pumps will be compatible with your Headshok, no need to spend too much.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    I just use some off brand shock pump with a gauge and a bleed button. Seems to work well.
    When I had a head shock. I'm a Lefty now.
    Lead by my Lefty............... right down the trail, no brakes.
    Reputation: jdr01930's Avatar
    I use a Wrench Force pump.
    Works great on my lefty, swinger 3way, and the headshock on my old Delta V
    '15 Cannondale Trigger 27.5 Carbon 2
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    '08 F6 Lefty (son's)
    Mar 2006
    I use an old Buzzy Pollinator pump, it was inexpensive when I got it back in '99. I had a small problem with it last week but it was user error go figure.
    Reputation: az1jeff's Avatar
    Feb 2007
    Rockshox. It pivots.
