Results 1 to 2 of 2
    brf
    brf is offline
    Reputation: brf's Avatar
    Headshok damper oil
    My headshok was losing air, so I stripped it to change the O rings then curiosity got the better of me and I opened the damper, which dumped all its oil on the floor.
    What weight / type / volume of oil do I re-fill it with?
    Thanks,
    Ben
    Feb 2005
    Bummer dude, you need tools at this point, to avoid damaging seals during reinstallation. It's 5wt oil though, Golden Spectro is OEM, if you care about that. If it's leaking air, you'll need new seals for the air piston, may as well change them all since you're in there.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
