Results 1 to 2 of 2
    Reputation: backcountryeti's Avatar
    Headshok on any frame?
    Is it possible to put a headshock on any frame? Just curious.
    PCC
    PCC is offline
    There are adapters made to allow you to mount a Lefty on to a 1 1/8" head tube. I think there is one for the 1 1/4" head tube, too. I believe that you are out of luck if you are trying to mount it on to a 1" head tube or if you are trying to mount a Headshock Fatty. If your head tube is 1.5" then you can probably just bolt it all up and go, including the Fatty.
