    Which Hayes adapter for rear disc on super V?
    Hi all,
    Just picked up a gently used set of wheels and discs from a friend at work. Front went on smooth, but looks like I need some kind of spacer or different bracket for the rear. Couldn't figure it out from Hayes site.
    So, anyone know what adapter I need for the rear mount on my super V to work with a hayes MX2?
    Thanks in advance folks!
    Heres a pic of the Bike before the swap... Not sure of the model, its an e-bay frame build up.
    Reputation: rw420's Avatar
    Dec 2005
    Quote Originally Posted by Escher
    Hi all,
    It's a standard IS to Post rear adapter.
    http://www.speedgoat.com/product.asp?part=40451
    IS Rear, 6" (98-15073) - assuming you're using a 6" rotor
    Shimano and generic adapters will work as well.
    He who follows his heart.
    Reputation: Scathel's Avatar
    Post deleted - misread OP
    Thanks for the reply.
    You are correct... after some research, I had to use some brass washers to get the offset correct.
    "...You can fight without ever winning, but never ever win without a fight..." Rush - Resist
