Results 1 to 31 of 31
    TrailRider420
    Reputation: TrailRider420's Avatar
    Hardtail Beast of the East
    So Ive got a 97 Beast of the East and its still rigid right now but Im going to be putting front suspension on it. I have a pair of rock shox judy xc but the steerer tube is longer on my cannondale than the haro they came off of so Im not able to mount my stem on it.
    I do alot of city riding during the week and trail riding on the weekends so I want something with lock outs and I want mounts for disc brakes.
    What shocks should I put on it? (1 1/8th steerer tube)
    Im looking to spend probably $200 or less
    What's "social pace?"
    first off, unless you are talking about a lefty, the front suspension is a fork, not a shock (a lefty is a strut).
    find out what length steerer you require (err on the side of caution). you should pick up something with at least this much steerer. used would be a good idea given your budget as that barely buys you anything new. avoid the RS Dart line as its lockout doesnt have a blowoff circuit so if you hit bumps locked out it'll eventually kill it.
    Quote Originally Posted by TrailRider420
    interested in any progress you might have made on this quest. i'm looking to get my hands on a beast and would most certainly upgrade to a used front fork suspension.
    If the Judy XC is sticking out just enough, you can just go with a threaded stem and headset.
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Dont do it!
    The beast headtube is not designed for a suspension fork. (at least not a current loong travel one.)
    gfy
    Quote Originally Posted by damion
    can you explain that out a little more?
    Without knowing the proper answer I'm guessing the headtube angle isn't raked enough to allow for a longer fork without making the front of the bike higher than it is supposed to be
    Reputation: Bubba74's Avatar
    Feb 2007
    I would guess that Damion meant that the frame has a short axel-to-crown length, and putting a modern fork on it would slack out the headtube angle and put too much pressure on the frame.
    Second that, a modern fork is to long resulting in slacker angles, making the bike less efficient and slows down steering. Might be what you look for in a DH machine, but the Beast is not build for that kind of abuse.
    Here's a link to a nice shedule where you can see the effects of an increase fork length. Although not Cannondale, but you''ll get the idea.
    http://www.liteville.de/v/25_30/lite...oessen_301.pdf
    As it is in German, a small translation; look at the second table, A = TTlength, E = wheelbase, H = BBdrop, I = seatangle, J = steererangle.
    Your old form prob has a build hight of 40cm or less, currens forks 43 to 45cm, so look at the numbers in the +30mm table.
    If you look for more comfort, try to find a nice old steel fork and go with a 2.4 sized tire.
    Reputation: baalan's Avatar
    Nov 2007
    I built up an M800 with the Beast geometry using an 80mm fork and the steering wasn't that bad.
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    Jun 2003
    A few things.
    1. How original is the bike now?
    2. If you decided to upgrade, you would need a very short (A-C and travel) fork to keep the handling as close to original as possible.
    3. The headtube. The HT on the older bikes were not designed to take the beating that suspension forks bring to the trail. If the rider is light, that may be fine. My peace of mind is worth quite a bit, personally.
    gfy
    Nov 2007
    How can a rigid fork be easier on a headtube than a well designed suspension fork?
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    I installed a rockshox on my my old 1991 M500 back in 1994? The thing rode very well handling wise. So maybe go with a shorter travel fork in the 80mm range?
    Nov 2006
    my '92 M800 w/ marzocchi bomber fork (100mm). geometry is slow but it's still a great bike!
    TrailRider420
    I havent had any progress towards an actual purchase yet cuz Ive been upgrading everything else on my bike first.
    Thinking of only getting 80mm as I dont do any hardcore riding. Some trail riding on the weekends and stuff but nothing that should be too much for the head tube to handle.
    Jun 2003
    I am not sure.
    Quote Originally Posted by baalan
    However, smarter heads than I have decided that a sus fork at full compression is harder on a head tube than a rigid fork.
    gfy
    Nov 2007
    It would be interesting to see the data regareding sus forks and head stress. How can we find out more on the subject? Another thread or what?
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    it's not that a suspension fork is harder on the headtube, it's the angle between the headtube and the ground. that's why they specify a range for permissable "axle-to-crown" height. the slacker that angle, the more bending stress on the underside of the headtube-to-downtube weld.
    TrailRider420
    Would there be any downside to me getting 100mm and putting less air in the positive chamber so when I sit on it its down a little farther and then fill the negative chamber with a little more air so my recovery (or whatever its called) is quicker. Or would it just be better to only go with 80mm.
    Does this make sense to any of you?
    (BTW Im sure you figured this out but I definately want some type of air shocks. Thinking about rockshox reba or something pretty similar)
    It probably won't feel as responsive
    I Love my Rize
    Reputation: danoalb's Avatar
    Dec 2005
    Good job! Get it
    I've been running a 100mm RST Omega TNL one inch threaded fork on my 96 m500 for about 2 years now with insane miles on this setup in all types of terrain and it is awesome. Set the sag with the preload soft and you will be good to go. Your bike can take 500 mm axle to crown safely and the RST Omega is only 480 mm. 19.7 inches would be about 500mm
    Here is the Official Cannondale table......... http://www.cannondale.com/asset/iu_f...echnote_en.pdf
    Early to bed early to RIZE makes a man healthy, wealthy <(scratch that) and wize.
    RIGHTY on a LEFTY
    TrailRider420
    Quote Originally Posted by danoalb
    This helps out alot on deciding how much travel I should get. My fork now is about 15.5 inches so that leaves me with about 4 inches to work with which is perfect for me.
    Now to decide on which shox...
    I Love my Rize
    Dec 2005
    Just remember
    Even though it is safe the longer fork will change the geo on your bike. You might have to get a longer stem and move your seat foward a bit to get some more weight for climbing but that said the slacker head angle is KILLER for steep downhill. Stable as a rock.
    RIGHTY on a LEFTY
    TrailRider420
    Ive actually got a 130mm 6 degree easton ea70 stem on it now but Im going to be putting a high rise stem and some road bike bars on it in the near future.
    Im hoping the geometry will fit me a little better with the longer fork cuz its just a tad small for me. Seats moved back as far as possible right now.
    Does slacker head angle means its just angled more? Im a newb when it comes to bike terminolgy
    I Love my Rize
    Dec 2005
    Can you say chopper? Just an exaggeration. Your front end will be higher and you steerer tube will be not as straight up and down more angled. Got it???????
    RIGHTY on a LEFTY
    I ran an answer Manitou SX-Ti on my Beast for years. I think the travel was 80mm. Once you set the sag on it, it handled like a dream. If you can, I would suggest measuring the distance from the bottom of the headtube to the center of the axle with your current fork installed. Then go to the LBS and compare that measurement to that of some forks on similar bikes. Maybe you can get an idea of how those forks would fit up on your Beast. Good luck.
    TrailRider420
    ok, thats what I thought. Just wasnt sure
    My 95 Beast had an original Judy XC (gold one) - I think was ~60mm travel. I had to put a suspension fork on that bike cause a) it was too loght on the front, I couldn't keep the front end planted on climbs, b) it was twitchy slow - the longer axle2crown slowed the handling down a touch, although it was still twitchy - the bike wasn't good and stable til you got it rolling good. I would guess the 80mm fork would be about perfect, and 100mm would be fine too - look for somethinglike a Reba that can be set at either height and see which you like best.
    Jan 2009
    Did you ever finish your project?
    Here's mine. I think it's a 96 with 95 stickers. It's a replacement frame for my original 90, so C'dale probably just supplied what was handy. I've been happy with the old Manitou Ti Buldge fork. Works good for the kind if riding I do -- cross country with some semi technical single track... well and pulling my 4 year old through the woods on an Adams tag-a-long
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    If I get a chance I'll photo mine when I get home next weekend.
    I have a 93 M800, with a Rockshox Mag21 (1 1/4"). It's converted to a single speed with a Surly.
    Fun for many rides, But it lets you know it's aluminum.
    PK
    TrailRider420
    So Id been laid off from my job in december so I was having to wait a while til I could put a new fork on. A buddy of mine just bought a trek 4500 and sold me the rock shox judy tt for $15. Took it out for a ride and I had tons of fun. Aftere riding rigid for a season Im glad to have at least some suspension. Even if its not the greatest. Now that im working again Im still going to be putting a better fork on. Still dont know what though yet.
    Have pics coming soon...
