Results 1 to 5 of 5
    Reputation: Ray Lee's Avatar
    Gemini DH manual and Thru axle
    Looking for a manual and an axle for the DH model (150mm), any help would be great.
    Anyone know if any rear 12mm axle fits or is it Cannondale specific or even a specific one for the Gemini DH frame?
    http://www.cannondale.com/usa/usaeng...plement_en.pdf
    it is not for the DH version
    The axles are ovalized on one side , to prevent turning in the frame , the frame is also ovalized at this point
    Thanks, I really needed the DH version manual.... I have a regular Gemini and was thinking of getting a used DH frame and would have gambled that I could find an axle but decided to pass without any geo info on it.
    Quote Originally Posted by MX_Lyrik
    A Judge axle will work. As stated the Gemini's were crafted to be ovalized so that you could take them apart on the trail using only one hex wrench. The ovalized side holds itself in place. One of the best frame/swingarm designs ever built. .....back when they were all made in the USA!!
