Results 1 to 5 of 5
    Front Sus Help - EST1000
    Greetings to all..
    Pretty new to the forum here, though i've been reading (and lovin) the large amount of information + ppl here on the threads...
    Happened to find my old bike from whence i cycled around college in 1994: A cannondale EST1000.
    After a complete tuning, the bike works wonderfully. Only trouble is, i'm now 30 pounds heavier then before, and would really looove a better front fork, one with at least some travel, vs the @!$#@ pepperoni it came with.
    Does anyone have any idea what fork, or recommendations as to the forks this particular bike would take? I went around my neighborhood bike shops, and all they said were that such forks are not made anymore
    And if you do have a fork that would fit this bike, and would like to sell it, pleasssse feel free to drop me a PM.
    Thanks in advance for your help.
    Trevor
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Check ebay for an old Rockshox MAG21 (As parts for it are still available).
    A 'modern" fork won't fit as the E.S.T. uses a flex stem with a 1 1/4 steerer tube I believe....
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Thnks so much for the advice..
    hmm.. MAG21.. wow, doesn't come up quite often.. even those that are on Ebay are all 1 1/8.
    What about the older Judys? Would they work?
    Ridin' dirty!
    Quote Originally Posted by trev2401 View Post
    As long as the steerer tube diameter is the same any fork will fit.
    Oh, and another thing is that your fork uses a threaded steerer tube with the Girvin stem being a quill stem so you have to look out for that too.
    Instead of upgrading your aged EST I would strip it, sell it in parts and check the classifieds for a newer bike like a Super V , 1st Gen Jekyll etc......
    True... hmm.. sigh..
    Ok.. the search's on for a V/Jekyll then..
    thanks once again for the help.
  1. Replies: 15
    Last Post: 02-06-2011, 06:42 PM
  2. Half an Inch Front Wheel Movement when front brake is applied
    By Jacques Pienaar in forum Brake Time
    Last Post: 11-16-2009, 07:21 PM
  3. Replies: 13
    Last Post: 12-29-2008, 11:11 AM
  4. e-type front derailleur, downshifting issue, do they work w/ triple ring up front?
    By mmatador22 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2008, 07:57 AM
  5. Parts help: chain link, front gears, front derailuer, more
    By serval in forum Bike and Frame discussion
    Last Post: 12-13-2005, 07:14 PM
