Results 1 to 9 of 9
Thread: Frame Set
    Frame Set
    Has any one ordered a frame set from Cannondale.
    I'm thinking about ordering a BBQ jekyll frame with the Lefy Max TPC+. and building the rest of the bike my self.
    I guess the lefty would come attached to the frame so I wouldn't need to but the headset.
    Using mail order if I have my calculations right I can build it up with XT spec. for under the price of a Standard Jekyll 1000.
    Are there any problems that I could run into ? I assume all running gear is standard except for the left front hub.
    Reputation: jm03's Avatar
    I'm not trying to question your budgeting, but what are you able to get the frame and lefty tpc for, i assume your getting the ti spring too. Because i've considered that, but never even came close to the cost of the instore pre built bikes. I assume your comparing to the jekyll 1000, and then adding the xt crankset?
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Good luck.
    Quote Originally Posted by roadrunner
    Even at a pro-deal, you will have a rough time matching the price of a pre-built. What is the $ on the Lefty Max, the front hub and the frameset alone? If you order the frame, and the fork, the fork will not be installed. Are you adding the cost of the wheel build?
    gfy
    Frameset
    The cannondale frame set is 1199 if you exchange an old frame (doesn't have to be a cannondale). Not sure what the price would be in $.
    I went through a Mountain bike magazine and and picked all the parts from mail order and totalled up all the prices. I was banking on the fork coming attacthed to the frame, so if this is not the case a Cannondale headset will need to be added. I also have left off the lefty front hub as I haven't got a price for that. I'm still only thinking about it in theory.
    If it doesn't work out, I guess I'll wait until the 2005 bikes come out and see if I can get a good deal on a 2004 J 1000.
    Jun 2003
    No fork on the Frameset.
    The fork will not come with the frameset. The headset will. THe headset bearings are the same for a Lefty or a Fatty. The Lefty front hub is $90.00 retail. Good luck with the search.
    gfy
    Lefty
    The Lefy and the manitou swinger definately come with the frame attached or not attached.
    For the basic frame and Fox shock the price is 679
    Jun 2003
    I stand corrected.
    I was thinking aboout that last night. 1200 pounds did sound steep for just the frame. I do not think we can buy a frame/fork combo like that stateside. Good luck.
    gfy
    ceteris paribus
    Reputation: xctico's Avatar
    Also keep in mind that if the Cdale bike is not assembeled by an authorized Cdale dealer then the warranty is void, and that's not cool.
    Jun 2003
    That is typical.
    Quote Originally Posted by xctico
    Most large companies are covering their arses that way. I can not blame them.
    gfy
  1. Bought a frame with a crack
    By MegaVolt in forum General Discussion
    Last Post: 06-18-2009, 11:51 AM
  2. How to buy an old steel frame?
    By Matno in forum General Discussion
    Last Post: 05-12-2004, 01:07 PM
  3. Is $830 a good price for a Trek OCLV 9.8 frame?
    By Theadict in forum General Discussion
    Last Post: 03-29-2004, 12:25 PM
  4. more mistaken 4-bar analysis
    By derby in forum Bike and Frame discussion
    Last Post: 03-11-2004, 05:20 PM
  5. A friend's broken frame
    By mountaingoatepics in forum North & South Carolina
    Last Post: 03-10-2004, 04:49 AM
