Results 1 to 3 of 3
    Sep 2004
    fox talas on prophet?
    is it okay to put a fox talas rlc 130mm on a prophet frame??? i have a current frame w/c will most likely be a donor to a prophet frame, since i have a non lefty wheelset etc... im contemplating on putting my talas to a prophet frame, is the talas too short for the frame???? im concerned about the geometry etc....
    Feb 2005
    it will work in europe they sell a prophet sl which has a 110mm for on it, so if you already have the fork I would say go for it. If you are thinking of buying the fork then i would look into getting s float 130 instead because you probably won't have to run the fork at less that 130 and it is a bit cheaper.
    www.treefortbikes.com Just lauched V2.0 with free shipping and low prices!
    Light, Strong and Long
    Jan 2005
    will work fine
    the talas will work without a hitch. You'll just need to get a 1.5 inch reducer headset for it
    to work with the prophets oversized headtube. The leftys axel to crown height is pretty low,
    so the talas shouldent mess the the geometry too much. Specially if you ride the bike in
    the lower fr position.
    Everyones got a little weight weinee in them
