Results 1 to 2 of 2
    New question here. Fox Float on Cannondale Jekyll 400
    I have a Cannondale Jekyll 400, which comes with the basic fox float. What is a good PSI to keep it at? I do like it to be a little lose to soften the ride up. I've been told weight plus 25, but that is only 205 PSI.
    Reputation: mtbykr's Avatar
    psi
    if you want a plush ride, then 90% of your weight. if you want a stiff ride (lots of climbing, ect...) then your weight plus 10lbs. consider getting your fox pushed by darren at push (www.pushindustries.com ) it will make a huge difference
    Good Luck
    The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' --Ronald Reagan
  1. Loose Fox Float fork
    By markom in forum Shocks and Suspension
    Last Post: 07-08-2008, 10:52 AM
  2. Jekyll Fox Float Pro Pedal-HELP!
    By GaryS in forum Cannondale
    Last Post: 06-19-2004, 02:56 PM
  3. How to set up Fox Float 100rlc and Fox Float triad
    By mark747 in forum Shocks and Suspension
    Last Post: 06-13-2004, 07:38 PM
  4. Fox Float 125 RLC vs Fox Talas ????
    By slowtwitch in forum Shocks and Suspension
    Last Post: 06-02-2004, 08:29 AM
  5. Fox Float vs Fox Float R with Pro Pedal
    By ManBitesDog in forum Shocks and Suspension
    Last Post: 02-27-2004, 11:41 AM
