Thread: Fox Float
    Fox Float
    Got a 2006 Rush 600 with a Fox Float rear shock--decided to dial it up a little yesterday as I am gaining some weight. Pushed it up to 155 and noticed a little oil coming out of the stem. Is that normal?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    I suppose you mean the valve stem... if it is just a little bit, it should be fine, specially if the valve is positioned on the "lower" side, since gravity will take the lube in the chamber towards the valve...
    Ground Pounder
    Reputation: MrHappyMedium's Avatar
    Feb 2007
    This happens on my Float R and Lefty. From the Float R it was a light oil and from the Lefty ('06 Speed DLR 110) it was a heavier oil and more of it.
    I try to avoid removing pressure from them because losing oil on every air release can't be good. Plus, it needs to be done for the needle bearing reset on the Lefty...
    Would reversing the mount of the rear shock help with this?
    My bicycle gets more dirt than your 4x4.
    Quote Originally Posted by MrHappyMedium
    It could help if the valve is on the "higher" side of the shock... but anyhow you should put some oil in when you do the air sleeve service (every 6 months or so)
  1. Replies: 14
    Last Post: 03-22-2012, 06:55 PM
  2. Nomad shock'ing story: Float>Rocco>Push Float!!!
    By BanzaiRider in forum Santa Cruz
    Last Post: 03-24-2008, 09:28 PM
  3. Talas Float R -vs- Pushed Float R weight
    By redrock_z71 in forum Weight Weenies
    Last Post: 06-07-2005, 09:41 AM
  4. Float R to Float RL upgrade advice please
    By Dombo in forum Shocks and Suspension
    Last Post: 02-01-2005, 10:35 AM
  5. How to set up Fox Float 100rlc and Fox Float triad
    By mark747 in forum Shocks and Suspension
    Last Post: 06-13-2004, 07:38 PM
