Results 1 to 9 of 9
    Reputation: J273's Avatar
    Flash post mount rear adapter confusion.
    Im wanting to replace the standard avids that came on my flash with XT's as thats what i use on most of my bikes.
    With the rear being post mount can anyone tell me if the calliper bolts straight to the frame without the need of an adapter with the standard 160mm rotor? or can anyone tell me what adapter id need for a 160mm rotor?
    Many thanks
    To me it looks like it would not need an adapter for 160mm. it seems as if Cannondale spec'd the rear to allow the smallest rotor to be 160 which seems weird as most allow for a 140. It just looks as if with any kind of adapter to space it out would push the caliper to far from the rotor. Are you planning on getting shimano rotors too? I'm not a fan of mixing brands.
    Quote Originally Posted by ace42 View Post
    Yeah I kinda thought the same. I'll have to wait until I recieve the XT's
    For now yeah i plan on keeping the avid rotors.
    Reputation: thatdrewguy's Avatar
    I have a carbon flash and I run a 140mm rotor w/Hope caliper and it is a direct mount without an adapter. For the 160mm I'm almost certain you need this:
    Name:  post mount 160.jpg
    Mar 2012
    I have a flash carbon with 160mm rear rotor and have to run an adapter see link. I know its an avid adapter but I'm using it with MT-8's with zero problems
    Cannondale Brake Adapter and Post Hardware for Avid 160mm - KP135 - CannondaleExperts.com
    the above photo is of a alloy flash with standard 160 pm, no mount is required. if it were a carbon flash - Matt116 is spot on.
    Jun 2015
    Does anyone know if an adapter is required when using shimano xtr disc brakes on a 2014 carbon f29.
    Reputation: tailwaters's Avatar
    I own a 2014 f29 and have a 160 rotor and there is no adapter. Caliper is bolted right to the frame mounts.
    Oct 2013
    2x ☝☝☝
    Sent from my Nexus 6 using Tapatalk
  1. Rear Post Mount on Cannondale Flash
    By MrSparklle in forum Cannondale
    Last Post: 04-30-2012, 05:57 PM
  2. XTR adapter for post mount rear
    By chowdownca in forum Shimano
    Last Post: 04-14-2012, 07:19 PM
  3. Post Mount Adapter for 180mm Rear Rotor?
    By myitch in forum Turner
    Last Post: 02-28-2012, 12:43 PM
  4. Replies: 7
    Last Post: 01-02-2012, 10:34 AM
  5. front post mount 180mm shimano adapter for rear?
    By DanielM3 in forum Brake Time
    Last Post: 02-19-2011, 11:56 AM
