    CSK
    CSK is offline
    Jul 2013
    Flash Carbon 29er chain tensioner?
    Hello to all! I was wondering if anyone had opinions on putting a light chain tensioner on a Flash Carbon 3 29er. I bought this bike a couple months ago and there seems to be to much "play" in the chain when I ride. Sometimes it will even drop a gear if I'm really bouncing it around. Also any opinions on the best upgrades to start with on this bike would be appreciated, except the tires I've already made my mind up on getting rid of them.
    Thank you for any advice.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Is your chain too long? Do you ride in bad gear combos (small chainring, smallest couple of cogs in the back)? Is your rear derailleur adjusted properly?
    It's hard to pin-point on an internet forum but you shouldn't need a chain tensioner unless you convert it to a single speed.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    CSK
    CSK is offline
    Jul 2013
    I havent adjusted anything since I bought it new and I'm not granny gearing it. So how does one go about adjusting the rear derailleur? I'm not exactly new to riding its just that my last bike, trek 8500, never needed it.
    Try a clutch mech. I havn't tried the SRAM ones but I swapped an XTR for XTR clutch mech and it much, much better. Gear shifting is a little stiffer but there's no chain slap, no chain suck and no noise at all now.
  1. Replies: 12
    Last Post: 05-27-2015, 10:01 AM
  2. 29er Throwdown: Flash Alloy vs. Flash Carbon
    By brentos in forum Cannondale
    Last Post: 09-16-2012, 11:36 AM
  3. Great CHEAP chain tensioner for Bandit 26 and 29er!
    By swaneedawg in forum Transition Bikes
    Last Post: 06-14-2012, 12:44 AM
  4. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
  5. Chain tug/tensioner - Outcast 29er
    By MRisme in forum Motobecane
    Last Post: 04-11-2011, 11:02 AM
