Results 1 to 10 of 10
    Reputation: sandyeggo's Avatar
    Mar 2011
    Flash 29er Sizing Question
    I've been out of mountain biking for awhile but I'm looking to get back into it a bit and would like to get a 29er.
    I've been a big Cannondale fan ever since my Rush (which I sold to get a Cannondale Roadie). I absolutely love the lefties.
    Anyway... I'm interested in the Flash 29er but it appears that the smallest frame size they have is a medium. I am a very short dude (5"7 on a good day) and my legs aren't particularly long either. My Rush was a small and fit well. Is a medium Flash 29er going to be too big? (obviously, I'd need to try it out but hopefully some of you knowledgeable folks could give me an idea if it is likely to be too big or not).
    Thanks in advance!
    I'm 5'8" with a 32" inseam on a medium '10 Flash 29. You might be able to make it work.
    I have longer legs with a shorter upper body. To get the bike set up right for me, installed a 90mm/-5deg SI stem and flat bars with 11deg sweep. Have the seat just forward of center and the seat post at the max.
    Take it for a test ride. Good luck
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
    Sep 2004
    I'm 5' 6" and have a Flash Carbon 29er 2.
    Swapped to 9 cm stem.
    I've been riding 29ers with 23" ETT so no problem.
    Look at the ETT and don't worry as much about standover....
    Reputation: brentos's Avatar
    You could make it work.
    But the bars will be too high in stock form.
    You'd have to ask the shop to swap out the 1 piece stem steerer with a 2 piece, you'll likely need a -20 stem to get the bars in a "normal" position relative to the seat.
    If you like the bars higher, it may work stock.
    Mar 2011
    Thanks for the replies, everyone!
    @creation rebel: dumb question - what is ETT? Is it the top tube length?
    @brentos: i do actually like the bars a tad higher.
    effective top tube..... look on the C'dale website and it will tell you what it is. Im 5'8" 30" inseam and ordered the med flash 1 29 alu.
    I'm 5'8" and wear 30" inseam pants. I test rode a Flash29er 1 Med the other day, and thought it had sufficient standover. Fit felt comfortable out of the box.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    my Flash 29er 1 this morning in the shop
    a Medium , fitting perfect for me
    Attached Thumbnails Attached Thumbnails Flash 29er Sizing Question-flash2011.jpg
    Reputation: steph26ne's Avatar
    Whaow ... Curuous about the upgrade you'll do :-)
    Waiting mine also. Ordered 1 week of january.
    When did you ordered yours ?
    FIRENZE rulez !!
    one day ago
