Results 1 to 13 of 13
    Flash 29er carbon 1x10 set up - any advice on MRP chain guide?
    Going 1 x 10 on my Flash Carbon 2 29er, unsure which MRP chain guide to use:
    - Should I get the direct mount SE/3 or could I use the seat tube mounted guide?
    Mountain Racing Products home of MRP, White Brothers, Kreitler, Tamer, and Power Grips | Shop
    The seat tube mounted guide looks cleaner, so would like to use this if possible.
    Also will use:
    - Homebrewed spiderless chainring 34T to go on XO Cranks
    - Already have a 11-36 cassette, plan to go 9-36 when Hope releases this.
    Also if anyone has any experience of doing this on a Flash 29er I' like to hear your views on how best to execute this.
    LA CH»VRE
    Reputation: Dan Gerous's Avatar
    I wouldn't get a seat tube clamped one, the frame wasn't designed to have something clamped around it's seat tube (is it even round in that area anyway?).
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Feb 2012
    Hey, did you get to setup your Flash with 1x10? I was thinking of doing this on mine, except for the 3bolt FSA cranks that don't work well with any single chain rings.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    i planned to do a 1 x 10 set up ...
    32 front , 11-40 rear
    If you have a clutch rear der (like SRAM Type 2), I believe you should just be able to use a narrow/wide drop-stop ring up front (like Wolftooth) and not have to deal with the chain guide.
    FIRENZE rulez !!
    i have a Di2 gruppo
    Only you Eliflap! You probably have carbon wheels on your car too!
    FIRENZE rulez !!
    ahahahahah , alloy rims ... i have not the carbon revolution wheelset
    https://www.youtube.com/watch?v=6IuoZp7-Hz0
    I have set up my carbon flash 1x10 with XTR clutch rear mech and race face narrow/wide ring recently. Works perfectly and no device needed.
    Quote Originally Posted by Bones01 View Post
    This is what I have done, Works flawlessly. I have a non clutch RD and have had no problems over the last 300km. I have even tried my best to get a drop.
    Reputation: 1-bar's Avatar
    I have a Flash Carbon 2 with sram crank and Wolf Tooth chainring (no chain guide) using an XX rear derailleur (non clutch), XX cassette and I have not had ANY chain drop. I would agree a clutch der. would probably give more assurance but it in reality it hasn't been an issue for me.
    OPEN Cycles One+ in stealthy black
    Dec 2011
    What type of spider are you using for your chainring? The SRAM 1x10 spider I tried put the 32t chainring up to the frame... I have the old 2x10 spider on now, but the 32t is still close unless I put it on the outside, but that messes with the chainline
    Another 29er Flash with 1x10 here - Absolute Black 30T front (narrow / wide), XT 11-36 rear, XTR clutch mech. No chain guard, Works great. Ridden that setup for 1 year and I've only ever dropped the chain in a VERY muddy race (so muddy that most people were pushing their bikes anyway)
    Ericw29er: Not sure about the Sram 1x10 spider but the CDale hollowgram spider has quite a bit of offset, so closest to the stays for a given front ring size. Absolute Black ring has a slight offset and Leonardi spider almost zero offset (I guess you could use at least 2 teeth bigger with the Leonardi)
  1. Going 1X10....questions about chainring choices, chain guide vs. bash guard
    By trumpus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2011, 06:29 AM
  2. Chain Guide Reco for 1x10??
    By MTBDad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2011, 04:57 AM
  3. e.13 XCX chain guide and Race Face 1x10 alignment
    By cyrjm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2011, 12:42 PM
  4. Need advice. Going 1x10 w/o ISCG and I need a guide and bash guard
    By woodyak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-22-2010, 06:06 PM
  5. Cannondale Flash Carbon 29er 1 Reviews/Advice?
    By Red Mist in forum Cannondale
    Last Post: 04-07-2010, 07:18 AM
