Results 1 to 6 of 6
    Reputation: rumshcawheely's Avatar
    Flash 29 hi mod 2011 vs 2012
    Are there any differences between the two frames?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Not that I'm aware of...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    There has been a change in top tube horizontal length. 2011 xl frames had an length of 64.1 cm. 2012 xl has a 62,9 cm top tube. I think the smaller frames also has been reduced in top tube length, but i have not checked this.
    Took a second look, top tube horizontal changed 12 mm in xl, 8mm in l and m. Head tube angle changed from 71 in l an m and 71,5 in xl to 70 degree for all sizes. Chain stay length changed from 44,4 cm to 42,4 cm for all sizes.
    LA CHÈVRE
    Looks like typo errors on the website to me... or they changed the way they're measured?
    Mar 2011
    I think there is a mistake on the webside:
    If you ceck the geo while watching at the Ultimate 29er Flash you see the geo of the 26er Flash's .
    If you choose the Flash 29er 1 you get the 29er geos.
    I have a 2012 warrenty frame (flash hi mod 29er ultimate=flash 29er 1) of 2012 an it has the same measurements as the ,, old '' frame
  1. Replies: 52
    Last Post: 01-29-2012, 07:14 AM
  2. 2011 X-Caliber or 2012 Flash 3 Alloy ?
    By JoeOxfordCT in forum 29er Bikes
    Last Post: 12-23-2011, 04:33 PM
  3. 2012 Flash Carbon 29er 1 on order
    By fueledbymetal in forum Cannondale
    Last Post: 08-01-2011, 11:39 AM
  4. Flash 29ers in size S for 2012?
    By Le Duke in forum Cannondale
    Last Post: 05-27-2011, 08:09 PM
  5. Replies: 0
    Last Post: 05-11-2011, 04:27 AM
