    May 2012
    Flash 29 carbon 3 advice please
    Hi, have the above on order and want to order x9 front and rear mech, can some one please confirm do I need medium cage on rear and is the front s3 bottom pull 39t, many thanks, regards Mark.
    Reputation: Flash29r's Avatar
    May 2013
    My current drive train consist of an x7 front downpull and an XT long rear. I run a 39/27 2x10 system and it works well for me. It is what came on the bike and I'm not changing either until it wears out. Idk if you can do a medium cage rear or not. I would think that would have more to do with what size cluster you run on the rear wheel more then anything. Hopefully this helps you, if you need more info lmk.
    May 2012
    Thanks, I'd better stick with the long cage then.
    May 2013
    Mine shifts very well and I have no issues. Only real issue I had was when I first bought it the shop that built it had the front shifter set up wrong. It was setup for 3x10 rather then 2x10 so I had this extra click I did not need and it shifted weird. I changed it and been flawless ever since.
  1. Replies: 12
    Last Post: 05-27-2015, 10:01 AM
  2. Replies: 8
    Last Post: 11-02-2012, 08:15 AM
  3. 29er Throwdown: Flash Alloy vs. Flash Carbon
    By brentos in forum Cannondale
    Last Post: 09-16-2012, 11:36 AM
  4. Cannondale Flash Carbon 3 vs. Flash 1
    By mnardo72 in forum Cannondale
    Last Post: 03-08-2011, 10:57 AM
  5. Cannondale Flash Carbon 3 vs. Flash 1
    By mnardo72 in forum 29er Bikes
    Last Post: 03-05-2011, 04:51 PM
