Results 1 to 7 of 7
    Flash & 156 Q factor
    My alloy Flash wasn't able to fit the 156 Q of the XX. It is BB30 and it just barely clipped the stays.
    Guess I'll have to order a 164 version if they're available.
    Anyone need a 156Q XX Crank 26/39
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    a friend installed a 164 on a Flash carbon frame too
    Is that a protective "sticker" on that crank arm?
    YB1
    YB1 is offline
    Anyone try a 156Q on a Scalpel yet?
    Emory Kalahari Kruiser
    Weekend Warrior
    Quote Originally Posted by YB1
    My thoughts as well. I might pick it up from you if we can find out if it works. Or I may just drop a ring off of my Cannondale Carbons.
    Anyone? Nice cranks, btw.
    "Single speed is the new black. Wait, black is the old black... Actually, single speed really isn't new at all."
    -HP
    I just bought one today for my 2010 Scalpel and will install in on Thursday or Friday and let you know how it works out.
    Reputation: andrepsz's Avatar
    Jan 2013
    Bummer, I feel so bad to see this thread....because I'm about to install one XX 156Q on my Flash ultimate Frame, I was confident till this point!
    My goal is to turn that ring adjuster to the appropriate clearance and add two spacers. While I'm waiting on the Bearing Shield (pair), I tried to fit just for reference and in fact the crankarm is like 1mm from the chain stay's on both sides....but I did not tighten it up for good...Should I keep confident?
