Results 1 to 5 of 5
    Fatty Ultra DL - travel not perfectly smooth
    Hi all. I'm having some trouble with my Fatty, I hope you guys will be able to help me at least pinpoint the problem.
    A while ago I bought a C'dale frame along with the Fatty Ultra. I've been collecting other parts during the winter and it's ready to be assembled.
    The lockout is working just fine and I haven't noticed any oil leaking around the boot. The boot isn't damaged. I haven't had a chance to take it for a ride yet, but when I pressed the fork through its full travel, I noticed that it doesn't travel perfectly smoothly - I don't know how to best describe it, but it's as if I can feel it kind of scratching inside. It seems to travel fine, but still. I don't have enough experience with suspension forks to tell what may be wrong, but I'm hoping for some insight on what may be wrong with it - and of course, if it's worth repairing.
    Re: Fatty Ultra DL - travel not perfectly smooth
    Anyone? :/
    Stubby-legged
    Contact mendon Cycle. Best Lefty/headshock service out there.
    telescopic rebuild! dr mendon cyclesmith is without a doubt your best bet.
    Dec 2010
    I had a similar 'issue' with an old Lefty DLR 2001, bought it second hand, lockout and rebound worked perfectly, no oil leaks or external signs of a problem... but it was rough as a bear's ass going through it travel... pulled the boot down and noticed small spots of rust on the inner races... so I went ahead and disassembled the fork myself (I have 'invested' in most of the Headshok tools as I own a few Lefty's and Headshok's.. I would highly recommend that you DO NOT tackle this job without them) turned out the races and bearings were badly rusted / pitted..
    Replaced all the rusted parts myself.. fork is now smooth as butter and 4 years on its still working perfectly..
    Easy fix in the end if you know what your doing.. but without the specific headshok tools, a micrometer for measuring the races and a lot of research your simply asking for trouble and may / will end up in a far worse situation...
    For peace of mind I would just send it to Mendon.. let him do his magic and your fork will come back good as new..
    FYI - the total cost of the tools alone will be more expensive than sending it to Mendon..
  1. Need help with my Super Fatty Ultra DLR...
    By jtidwell in forum Cannondale
    Last Post: 08-05-2013, 03:03 PM
  2. Fatty Ultra DL80 oil bleed
    By Rendisha in forum Cannondale
    Last Post: 03-24-2013, 02:32 PM
  3. 03 Fatty Ultra DL manual
    By haggis1978 in forum Cannondale
    Last Post: 09-28-2012, 01:29 PM
  4. Fatty Ultra DL rebuild - parts still available?
    By Harksaw in forum Cannondale
    Last Post: 03-19-2011, 06:46 AM
  5. HeadShok Super Fatty Ultra DLR 80 mm
    By Mrwinkle in forum Cannondale
    Last Post: 02-28-2011, 06:42 AM
