Results 1 to 14 of 14
    Mar 2006
    fatty sl saw off cantileverbosses ?
    hi, i want to saw off the cantileverbosses ,can i do this or is the fork hollow at this place.
    flo
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Why?
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Mar 2006
    my question is if it works or not . why? i want it to look like the ultra and i don´ like the cantibosses.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    I did it on a fatty 70 before, because just like you I couldn't stand the bosses when I mounted disc brakes.
    Cut them off leaving like 1/8" on the fork legs and use a file or a dremel for the rest.
    The bosses are solid, but be careful not to cut into the actual fork leg, since the aluminum is VERY thin!!!
    If you plan to get the fork painted it's better to leave more material on the fork and to smooth the area with some body filler.
    Mine was a pain in the behind, since I polished the entire fork and any imperfection would've showed.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Feb 2007
    Neat job! BTW are they really yellow zip ties? That's attention to detail.
    Mar 2006
    o.k. that´s my plan too, the finish with file and sandpaper. but is it possible to cut off all off the arm of the cantis that it looks like the fatty ultra fork ?
    flo
    Ridin' dirty!
    Quote Originally Posted by Baker921
    Thanks...Yes they're yellow too
    Were friggin hard to come by though....
    Don't saw them off.
    Ridin' dirty!
    Quote Originally Posted by flo74
    flo
    Yep...that's possible. I COMPLETELY removed mine.
    You can't be heavy handed though... (I guess it helped me being a Dental Lab Technician here)
    As you file them slowly down, if done with proper care all you'll have left is the weld seam in the shape of a square.... I removed those too and polished the entire fork...not even at closer look you could tell the fork had Canti-bosses...
    It's an all day job though, so be patient.
    Mar 2006
    Quote Originally Posted by cdalemaniac
    o.k. thanks for your reply ! now i must ask here , is here anyone who will sell me a super fatty (the ultras are way overrated and too expensive in my eyes) ?
    flo
    Feb 2007
    Plenty of Ultra forks on ebay. Less of a hassle,no?
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    I'd have see what I have laying around.
    Exactly which model do you want? Color? etc.
    PK
    Ridin' dirty!
    Quote Originally Posted by speedmetal
    Yeah...if I needed a fork now I'd rather spend some extra $$$ not have the hassle of cutting the bosses off again!
    I only did it because I already had the fork and then switched to disc brakes...
    Mar 2006
    anyone her who know at the delta v500 where i can adjust the fatty?
