Results 1 to 9 of 9
Thread: fatty SL
    fatty SL
    Hey Folks,
    How hard is it to do routine maintenance on a Fatty SL headshock?. Are there any manuals or websites that will walk me thru it?
    thanks in advance
    Hairy
    Reputation: amillmtb's Avatar
    Jun 2005
    http://www.cannondale.com/tech_cente.../headshok.html
    Pick the fatty that you have in the instructions section, and it might have a diagram in it. If not, im sure someone here does.
    Nov 2006
    what does it mean when the cartridge still holds air (100+ psi) but bottoms out easily?
    Music & Bikes
    Reputation: fokof's Avatar
    Bottoms out means not enough air.
    Are you 220lbs + ?
    "There is a big difference between kneeling down and bending over" -FZ
    Nov 2006
    nope. i'm only 120#
    Music & Bikes
    Then I'd have at look at your shock pump. If you say it holds it's air and have 100psi air in it, the only way I see it can bottom out is if you drop 10 foot + drops or descend 45+ hills
    Seriously , when you remove your pump some will loose air, maybe yours ?
    Nov 2006
    negative, ghostrider. pump is good. measures pressures correctly. checked it on my scalpel
    Jun 2005
    Sounds like you need new seals, when was the last time you had a Cannondale shop or Cannondale do a seal overhaul? The seals could become porous and leak air after long periods of time. Cannondale reccomends that the seals be replaced once a year.
    Music & Bikes
    Quote Originally Posted by amillmtb
    He said earlier that his fork is holding up it's air..........
