Results 1 to 47 of 47
Thread: F4 build
    Reputation: Carbon 66's Avatar
    May 2010
    F4 build
    I picked up a 2010 F4 to get back into riding. <a href="http://www.cannondale.com/usa/usaeng/Products/Bikes/Mountain/Hardtail/Details/1290-0FS4-F4/">Specs</a>
    Here it is, all stock.
    May 2010
    Most of my riding is hardpack, so I changed the Nevagals to Small Block 8's. I will probably go with a Slant Six in the front when it gets wet. The stock stem was a little long so I went with a Thomson along with a Bontrager 40mm rise bar. After that was the Thomson seat post. Then I started buying XTR. 972 rear, 971 front, 970 shifters, 970 cranks.
    I'm at 12.25kg, 27lb's.
    May 2010
    Here's a list of component weights. I will update as the build continues.
    Frame Trail SL, double butted, mechanically formed, 6061 alloy
    Fork RST Deuce 1.5 Air with rebound adjust and lock-out, 100mm travel
    Rims Maddux DC3.0, double wall with eyelet, disc specific
    Hubs Shimano M475 6 bolt, 32 hole
    Spokes Stainless steel, 15g
    Tires Kenda Nevegal, 26 x 2.1"
    456 Pedals VP Platform plastic
    359 Point 1
    1215 Crank Shimano M442 Octalink, 44/32/22 with BB
    770 Shimano XTR 970 cranks and BB
    279 Chain Shimano, 9-speed
    263 Yumeya
    RearCogs Shimano HG50 Deore, 11-32
    176 FrontDerailleur Shimano Deore
    148 Shimano XTR 971
    282 RearDerailleur Shimano Deore
    197 Shimano XTR 972
    281 Shifter Shimano Deore
    224 XTR 970
    317 Handlebar Cannondale C3, 650 x 20mm riser
    230 Bontrager X lite 40mm rise
    193 Stem Cannondale XC3 1.5"
    194 Thomson 45mm w/two 5mm shims
    Headset Tange Custom 1.5
    Brakes Tektro Auriga Comp Hydraulic Disc, 160/160mm
    BrakeLevers Tektro Auriga Comp w/custom lever
    Saddle Cannondale C3, ergonomic design
    406 Seatpost Cannondale C3, 31.6mm
    228 Thomson Elite
    49 Seat post clamp Cannondale
    29 Thomson
    72 Aluminum bottle cage
    33 Arundel Dave'o oil slick cage
    334 2 Tubes
    230 4 cups of stans, 2 stems, and yellow tape
    May 2010
    I get these thorns all the time. They're part of my nightly ride. Here's a pic of three of them. You can also see two more imbeded into the tire to the left.
    May 2010
    Here's some tech
    No more tubes or patches. I went with the Stans yellow tape instead of the rim strip. The 25mm tape fits perfect in the stock Maddux rim. Keep the seam between the spokes. There are two sizes of Stans stems. The Schrader base is too wide so I trimmed it off.
    May 2010
    This is the video>
    http://www.youtube.com/watch?v=gWbYG...eature=related
    I used the Stans instead of soap and water to seat the tube. Two cups of sealant, 110g. After about 5 minutes I only had a few bubbles around the bead. A half hour later they was done.
    Reputation: zenkem's Avatar
    Look'n Good!!! I didn't care for the Maddux rims w/Shimano M475 hubs on my F4...a new wheel set was my first upgrade.
    I put them back on once to save some wear on my Schwalbe RR's during a mostly paved ride and the entire ride it felt as though I was dragging a refrigerator behind me...
    May 2010
    The Stans conversion dropped half a pound and works perfectly. There is almost no pressure loss between rides. Excellent product. The day I bought the bike I replaced the pedals with Easton platforms. 572g. The Point 1 pedals are 359g. In addition I replaced the aluminum bottle cage and seat post clamp.
    May 2010
    Quote Originally Posted by zenkem
    I have to agree. Rotating weight should be one of the first considerations. Waiting on the wheelset saved me some coin. I picked up a new XTR 975 set for $530 shipped. 1525g. This wheelset, combined with the XTR 975 160mm rotor, fits perfectly with the Tektro calipers.
    Luv the wheels!!! I recently swapped out the Tektro's for SLX's w/180mm both front and back. I now have a renewed confidence in my riding abilities. The Tektro's just weren't cutting it on the downhill's here in Germany...
    May 2010
    I have the front brake (post mount) and I'm trying to figure out the rear. Can I use a Shimano IS caliper and retain the 160 rotor?
    Quote Originally Posted by Carbon 66
    I went to my LBS who's a C'dale dealer and he gave the brackets...everything bolted right up. I'll post some pic's after I take a few of the new setup...
    I have been looking at an F4 too.
    What sizes did you guys get and what is your height / inseam?
    I tested a large and I felt comfortable with it as oppose to a medium and i am only a 5-7 with about a 28" inseam.
    I felt crowded with a Medium and if I would to put my legs on the pedals and at the top arch, my knee will touch the handle bar if i turn the bar by 15-20 degrees,
    Quote Originally Posted by skewe
    I have a 32" inseam, the XL fits me perfect...the L felt to small...
    Any idea why you went with a white as opposed to a grey?
    I am undecided. I have seen the grey in store and it looks sharp
    White, it looks good too but have not seen it in person
    Here's my build...
    OP, how much dose your ride wiegh with the XTR wheels...just curious...
    May 2010
    Medium 31" inseam. It's all about preference. The Thomson stem is a little short for me. (45mm 0deg rise) When I change the fork I'll change to a 1 1/8 stem.
    May 2010
    I would get the grey and post some pics here. I've never seen one.
    May 2010
    24-5 11.02kg Took off (29 oz. 826g). 63 cents a gram. Not bad for such a huge drop. I bought the wheels, rear derailer, and shifters from yourbestbikezone on ebay. Shipped next day and I have it in 3 days.
    Mine is weighing in at 27-7 with heavy wheels but I need 'em cause I'm a Clyde. I just couldn't see dishing out the cash for XTR's when I would just destroy them....
    Have you looked into fork options??? I was thinking 'bout going with a tapered sheerer...I think a Lefty would be kewl as well...
    May 2010
    I got the rest of my parts in. XTR brakes and cassette. I'm at 23lb12oz, 10.8k.
    That's all for now.
    In fact i just placed my order. Picking it up on Sat
    They only had the white one when I bought mine or else I would have thought about it...
    Yeah, the LBS had it grey only. i was going to order it online in white.
    Although i was paying slighlty more plus tax, i think the lifetime adjustment was worth it.
    Have any of you guys had trouble with sand getting in the lower bearings of the Headset??? I asked my LBS (C'dale dealer) for a sealed bearing setup but they didn't have one and told me to load it up with grease to keep the sand from getting to the bearings....
    Nope. Been on a few trails from sandy trails to dry rocky creeks and i have not had the issue. Are you?
    Took her out today for her first snow ride...what a blast!!!
    " width="549">
    Looks like fun. Took mine out for a ride today but it was all muddy
    Here's one of the trail I was on:
    " width="549">
    Well, my RST Fork finally broke today while it's still ride-able I no longer have the lock out. This might be self inflicted when making an adjustment in the cold I heard a slight crack and after my ride I found the following:
    " width="549">
    This is the first failure I have had or heard of with the RST "Deuce". Gonna take it to the LBS (C'dale dealer) and have them take a good look and hope the warranty will cover it...more to come...
    Might be a good idea to go LEFTY
    or RockShox
    or RockShox
    You're talking about $1K, if I can get this fixed/replaced under warranty and ride for another season I'll be happy...
    I think you easily put in 1.5k in your new bike, what is another $1k
    I feel your pain man and I would go the warranty route if i was you too.
    You were adjusting the lockout on the top right? Not the rebound at the bottom.
    I was adjusting the bottom right and the shaft broke which in turn disabled the lock out. In colder temps you wanna make sure you have your fork set for faster rebound because the oil is thicker.
    I took the bike to my LBS and they said they'd ship the fork to RST and should have the issue resolved within two weeks...more to come...
    That is good to know. if ur in US and need some shocks
    http://classifieds.mtbr.com/showprod...uct=58141&cat=
    I think the price is pretty good. $240 forks for $170
    Yah, but none of those have a 1.5 steer tube...I did see a tapered one though...
    Zenkem, got your fork fixed?
    I am thinking of going tubeless.
    All I need is
    The sealant, people are saying to go non-ammonia sealant
    All I need is
    Nope not yet, the Holidays have got everything screwed up with shipping and all. My LBS got the fork back which I think is a new replacement because they said RST forgot to send them the star washer (don't know proper term) for the steer tube. They said I should have the bike back this week.
    I don't think you can go wrong if you go with Tubeless products...
    Just picked one up today, excited to see how it rides
    Reputation: bikerboyj17's Avatar
    All it needs now is a new fork. Wonderful build.
    Quote Originally Posted by wedman44
    You won't be disappointed!!!
    Might go tubeless on the front first
    Well I finally got my F4 back from the LBS with a new RST fork and I feel like a kid with a new toy. I had to pay 30 ($40) for Shipping and Labor but hay, now I'm good for at least another season.
    MFG recommends getting your fork rebuilt at least once a year so I guess the next one is on my dime. All said and done I think the RST Deuce is a awesome fork. I've put well over 1000 miles on this bike last year and was still riding it after it broke. I would put it up against any 100mm fork and I'm sure it would match up just fine...just my 2 worth...
    glad to hear.. my lbs have lifetime service, so i think i would hv gotten it free
    @ Zenkem,
    Guess what, my RST also failed. Regular ridding at a state park. Up hill and downhill. It is under warranty and I am not sure if i should upgrade
    http://forums.mtbr.com/cannondale/cannondale-f4-2010-fork-out-commission-warranty-upgrade-710380.html#post8065416
