Results 1 to 3 of 3
    F29 80mm Lefty noise
    Ever since the first ride of my F29, I have noticed an annoying sound coming from my 80mm converted SL Lefty. It occurs with any, even slight, undulation in the trail and happens throughout the entire ride. It sounds a little like a cable housing hitting the frame, but that wasn't it. I partially disassembled the Lefty, checked to make sure the damper was tight and that all bolts were tightened to spec'd torque. All OK. The sound is very easily elicited. I chased the noise around for an hour....when, I finally turned the bike upside down.....and there it was.
    I turned the bike upright....and there it was again, upside down, upright, upside down.....the noise was consistent.
    Then I figured it out.....those damn plastic travel spacers are sliding up and down the piston shaft and hitting each other making the noise.
    Has anyone else noticed this?
    Is there an easy fix? (Mendon?)
    F29 converted singlespeed, I9 wheels (355's), Avid Ultimate, Thomson Masterpiece, Karma 1.9 (w/Stans), Carbon SL Lefty = 19.92 lbs.....
    Feb 2005
    Quote Originally Posted by trauma-md
    Hmmm, typically those are a fairly tight fit, and don't slip around, they should just stick at the top of the shaft. Two thoughts. Tape them all together (clean 'em well, and use electrical tape), so at least they aren't clacking on each other, or try a bit of Teflon tape inside them, to tighten up the fit a bit. Good luck!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Good job! thats freaky light
    Holy cow, I thought my F29 was light at 23 pounds, thats nuts. Well done.
