Results 1 to 6 of 6
    don't stop
    DYAD RT2 Bushing Width?
    Anyone know the upper and lower bushing width for the DYAD RT2? I've got a trigger 29er coming, and going to try to sell an RP23 off my old Rize I'm retiring, but first want to know if I should hang on to the RWC needle bearings I installed on it, i.e. whether they might be compatible with the DYAD?
    Anyone out there upgrade the DU bushings on the DYAD to needle bearings?
    FYI The bushing width on my RP23 is 22.4 mm.
    Reputation: devojrx7's Avatar
    Where do you get the needle bearings? If I can find my digital calipers and they still work I might be able to measure my Trigger 29er for you.
    don't stop
    Real World Cycling: ABOUT RWC SHOCK EYE NEEDLE BEARING KITS
    Now that I think about this, I should probably just ask them.
    Thanks.
    Most likely 15.75mm. Check the last post.
    Enduro shock eye needle bearing kit
    don't stop
    Quote Originally Posted by devojrx7 View Post
    Any update on this? Did you find a kit that worked?
