Results 1 to 2 of 2
    Oct 2011
    Hope DT swiss XM 1550 Tricon 29 - question
    I am new here, and by sure this is a stupid question, I want to buy DT swiss xm tricon wheels for my Cannondale SL-2 29er, on DTswiss website the wheels have two option and I don't know the correct for my Bike:
    FRONT HUB: TRICON®, DT Swiss thru bolt, center lock
    FRONT: Quick release, thru axle 15mm (front wheel can order 9mm or 15 mm)
    REAR HUB TRICON, DT Swiss thru bolt, ratchet system, center lock
    REAR: Quick release, thru axle 12mm, X-12
    What is the difference betwen QR and thru axle?
    My bike has quick release standard 100mm Front, 135 Rear. I am concerned about the compatibility, some advise from you is appreciated
    Attached Thumbnails Attached Thumbnails DT swiss XM 1550 Tricon 29 - question-overview_tricon_xm.jpg
    Reputation: akt42's Avatar
    Jan 2011
    If your front fork has a slotted drop out then you want the 9 mm QR. 15mm Thru is for a fork that has a 15 mm hole, not slotted. It is a fairly new standard that most trail bikes are going to due the the increased stiffness of a thru axle. In any case, I am pretty sure that the 9mm hubs can be converted to 15mm if you later buy a fork with a thru axle.
  1. New DT Swiss TRICON XM 1550 Wheelset
    By Black RONIN in forum Wheels and Tires
    Last Post: 09-19-2012, 11:05 AM
  2. DT Swiss Tricon 1550 Hub Conversion Questions
    By polymathic in forum Wheels and Tires
    Last Post: 11-19-2011, 08:25 PM
  3. Mavic Cross Max SLR vs. DT Swiss Tricon 1550
    By shaft in forum Wheels and Tires
    Last Post: 07-28-2011, 08:44 PM
  4. DT Swiss Tricon XM 1550 15mm conversion
    By edbraunbeck in forum Wheels and Tires
    Last Post: 01-02-2011, 02:41 PM
  5. Replies: 9
    Last Post: 09-05-2010, 09:26 PM
