Results 1 to 3 of 3
    Caution;  Merge;  Workers Ahead! DT Swiss HVR 200 on RUSH
    Hello,
    have someone mounted the DT HVR 200 on a RUSH?
    Is possible to use the same bolt-set?
    Always Searching
    Reputation: _SYNAPSE_'s Avatar
    Dt Swiss Hv2 200
    You need the correct bushing set for the that shock and bike combo, check with your DT Swiss dealer. Let us know if you get this set up, would like here more about it's performance. The FOX RP3 is mediocre at best. +
    I would like to try another set up because the DT Swiss SD210 was a good shock on my 04 Scalpel team.
    Ok... I'm contacting the DT Swiss dealer tomorrow.
