Results 1 to 7 of 7
    Does anyone know how heavy is a f2 caffeine M size frame?
    i really would like to know and have been searching on google with no answers. anyone here happened to know?
    just the frame alone..
    thks!
    It's about 1550gr on digital scale
    Reputation: cannondaleportugal's Avatar
    yes ,merris is right ,1550 grams ,with nothing else on ,its a good frame but the new flash probably will be lighter ...
    regarding it's weight
    1550grams? that's not particularly light for today's standards in aluminium frames right?
    i understand good light frames are usually 1.5kg and below right?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Being aluminum, 3.4 pounds is still excellent weight for a hardtail frame. Nobody does aluminum better than Cannondale...
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by cannondalejohn
    A lot of the frames that are under 1500g are the carbon ones, there are definitely a few aluminum hardtails under that, but not many. I believe that the old Optimo frames are under that weight.
    not much point to further reduce the weight of 3.5 lb alum frame as durability will be compromised. I would rather look at other areas to save weight. Frame is only about 15% of the total weight of a hardtail
