Results 1 to 3 of 3
    Do I need to replace any seals. When installing bearing shields?
    Hi I want to put on some new bearing shields.
    Do I need to order any bearing seals or washers of any kind?
    Or can I just order the Bearing Shields and put them in.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    You just want to trade the red for green ones? Just use the rubber seals you already have (black rubber ring that's behind the sheilds, between them and the bearings) and refit the washers you had before.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Ok thanks I will do that.
