Results 1 to 3 of 3
    Wandervans
    Reputation: smilycook's Avatar
    Direct Mount removal Jekyll and Trigger
    I recently upgrade my 2011 Jekyll to 1x11 and my 2013 Trigger to a 1x10 and both bikes use the SRAM chainrings with the special teeth to help hold on the chain. So I am not going to run a chain guide. Now the question is can I ditch the front derailleur direct mount and bolt or does this serve another purpose?
    Live to ride!
    18 Cannondale Jekyll Carbon
    16 Diamond Back DB8
    https://www.facebook.com/wandervans
    wandervans.com
    Reputation: MarinCRO's Avatar
    Jul 2013
    You can remove it, but you'd have to remove the the chainrings to get to the mount first.
    This is a bit troublesome since you have to remove crank arm as well in order to remove the chainring.
    Mar 2011
    I'm sure the direct mount bracket holds the other side of the lower pivot??
  1. Front Derialluer XT-786 Direct Mount w/ X.0 Trigger?
    By mtnbikej in forum General Discussion
    Last Post: 09-13-2013, 02:24 PM
  2. Front Derialluer XT-786 Direct Mount w/ X.0 Trigger?
    By mtnbikej in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2013, 01:57 PM
  3. Pulled the trigger on a Jekyll 2
    By FreuderLocks in forum All Mountain
    Last Post: 07-29-2012, 06:41 PM
  4. Pulling the trigger on a jekyll, I think
    Last Post: 07-26-2012, 06:22 AM
  5. direct mount chain guide??? to replace direct mount der
    By TwoNin9r in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2012, 05:36 AM
