Results 1 to 2 of 2
    Mar 2005
    Determine stem size of a headshok?
    Noobie question, but how do you determine the stem length and rise of a headshok stem? Is there a code on the stem (somewhere I cannot see?) and if I need to measure it what are the need-to-knows - point to point and angle determination?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    What year model is it? For the last few years, they marked the stems with what looks like a serial number but it's actually the sizing code. Let's say you see a small number like 10005318...it means a 100mm stem, 5° with a 31.8mm handlebar diameter. On the bolted on stems, it was close to the steerer pinch bolts, on the stem-steerer combos, it was on the top around the steerer, under the plastic top cap. Not sure where they write it on the new OPI stem-steerers.
    If you can't find it: length is measured from the centerline of the steerer to the centerline of the handlebar. The angle is measured from it's side obviously, a 0° stem actually has a 90° angle between the stem's main tube and the steerer tube. a 95° angle means a +5° stem and so on.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
  1. How to determine best stem length?
    By pmg5727 in forum Beginner's Corner
    Last Post: 12-29-2009, 10:16 AM
  2. How to tell Headshok Stem size?
    By jdr01930 in forum Cannondale
    Last Post: 08-29-2009, 01:33 PM
  3. How to determine stem height
    By skiing9689 in forum 29er Bikes
    Last Post: 05-23-2007, 09:54 PM
  4. headshok boot to determine travel?
    By tristan in forum Cannondale
    Last Post: 04-16-2006, 06:22 AM
  5. How do you determine the degree of the stem?
    By MrAnderson in forum General Discussion
    Last Post: 04-22-2005, 07:07 PM
