Results 1 to 5 of 5
    Apr 2013
    D3 lock on grips HELP!
    So I was installing some XTR shifters and had to remove the d3 lock on grips, I was tryign to be gentle getting them out and the screw backed out, but it seems that I allowed the nut to fall into the handle bar leaving the other half of the endcap in the bar. Now I have no way of securing the caps. If anyone has any advice or insight on how to gently remove the inserts so I can get the nuts out and reinstall them properly please advise.
    If the end piece did fall inside the bar....you should be able to use a hook and pull the expander out easily.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Quote Originally Posted by the mayor View Post
    Or push it out from the other side...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous View Post
    If it's a riser bar....that probably won't work.
    It should come right out if the swedge nut is out.
    LA CHÈVRE
    It would still work with some cable housing or something.
  1. Best Lock-On Grips?
    By ryanlee in forum Specialized
    Last Post: 08-24-2012, 08:50 AM
  2. Let's See Your Lock-On Grips!
    By Golf Nut in forum 29er Bikes
    Last Post: 01-13-2012, 08:25 PM
  3. Let's See Your Lock-On Grips!
    By Golf Nut in forum General Discussion
    Last Post: 01-10-2012, 09:19 PM
  4. Hey giant lock on grips
    By bardynt in forum Giant
    Last Post: 11-04-2011, 01:48 AM
  5. Lock on grips!
    By The Grimmer in forum All Mountain
    Last Post: 03-28-2011, 11:46 AM
