Results 1 to 2 of 2
    Reputation: surf418's Avatar
    Crankset spacers
    I ride a Rush alloy 2008 with a Truvativ Stylo GXP crankset. It got a bottom bracket Truvativ GXP and there are 2 spacers (1 per side).
    I bought a Truvativ noir crankset with a new GXP bottom bracket (no spacers included).
    My question is do i have to put the spacers on the new setup or its meant to be without?
    08 Rush 4 - 650B
    10 Synapse 5 Carbon
    Quote Originally Posted by surf418 View Post
    Generally speaking, the spacers should be 2.5mm each and are meant to be used with a 68mm bottom bracket shell. If you have a 73mm shell, you don't need the spacers ( 68mm + 2x2.5mm = 73mm) . Previously, I have owned a 2007 Rush alloy and it had a 68mm shell. I used the spacers but as I recall, I may have used two on one side for a better chain line. The book installation however is one on each side.
  1. Shimano LX M580 crankset - how do I know how many spacers to use?
    By djork in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2009, 06:36 PM
  2. Where to find crankset (chainline) spacers???
    By alphakappa3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2009, 11:31 PM
  3. XT Crankset and Spacers?
    By seawind161 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2008, 09:38 AM
  4. shimano XTR crankset on new scalpel, Spacers ?
    By sebastian21 in forum Cannondale
    Last Post: 05-01-2008, 06:09 AM
  5. Do you need to use all the spacers on a Hollowtech II crankset (XT m760)?
    By @dam in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-05-2005, 11:35 AM
