    cannondale rider
    Reputation: rshank3499's Avatar
    converting a F3000 mountain bike to a cyclocross bike
    I want to turn my F3000 into a cross bike for this comming cross season. Right now it has a left fork, but I want to replace it with a rigid fork. Is it possible to put 700c road wheels on the bike as well with cyclocross tires? I also want to run disc brakes as well so I need to get disc compatible wheels as well. Has anyone else done or tried this?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    It's possible, running 700c wheels. However, you cannot run rim brakes anymore(disc brakes only). But, the tires gotta be either 1.0" or 1.5" wide, tops. It's a real close, tight setup that should work well.
    You running 26"? If not ild get a 29r and put some 700/35 on it...26" wheels will get smoked by the 700 club
    Reputation: CabezaShok's Avatar
    Oct 2007
    Quote Originally Posted by Zachariah
    Possible on newer frames.....but i doubt 700c's would fit my 01' F600 becouse its got different rear seat stay, (U-shaped at the top)
