Results 1 to 7 of 7
    SOC
    SOC is offline
    Convert Separate Lefty Stem/Steerer Tube to Integrated Stem?
    I have a Lefty equipped Prophet with a separate stem and steerer tube. The cockpit is currently set up just right for me.
    Is it worth it to switch from the separate steerer/stem to the integrated stem?
    I'd be keeping the exact same stem specs.
    Are there any compelling reasons to switch other than saving a few grams in weight?
    Any reasons I should stay with separate steerer/stem?
    Am I wasting my time?
    I have a chance to buy an integrated stem for about the same amount I could get by selling my current stem, so cost-wise it should be net neutral.
    Your thoughts, comments and feedback are much appreciated.
    Thank you.
    Feb 2005
    They cost a boatload, require a special tool for easy install and removal, and save so little weight, I'd think you could fart and save more
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    If your Lefty is the carbon version with bonded clamps, you should be able to use the 1 pc stem. If it's the alloy version, no go! The lower clamp is also the steerer tube.
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
    SOC
    SOC is offline
    Lefty is 140mm alloy - I'll happily stick with my current set up.
    Thanks for the replies and pointing me in the right direction.
    Quote Originally Posted by MendonCycleSmith
    Hello,
    Excuse my english comprehension (and this time, google's transletor don't help too much ).
    I have a 2008 Rush 5 with Lefty (110 DLR Speed Al) and I'm in the same case than SOC. My usual bike shop, advised my to change my current system (normal stem) to integrate system when I ask for a HOPE stem.
    What I understand about all your ansewr is that is not better the integrate system, is this correct?
    Thank you very much and again, apologies my english.
    PRM
    PD: Be happy.
    Nov 2006
    @dormilon i would only switch if you have to change stem length/angle
    Thank you dypertec!
    PRM
    PD: Be happy
