Results 1 to 11 of 11
    Constant migration of bearings
    Hi!
    I own a Lefty Max 140 TPC from 2006 I guess (the one with the easy to reset bearings .... lose topcap and so on...)
    Okay the point is that I need a reset of bearings every 50km/ 3 hours of riding.
    It migrates for about 30mm in this time.
    If it would be every 30 hours it would be ok, but this way, it suck$$
    The spring is right for me, 25% sag.
    The fork was away at a shop who calls himself a specialist in Headshock technology.
    It is super smooth without any freeplay.
    Can you help me out? How can I fix it?
    Thanks a lot!
    reno
    Reputation: Duncan1104's Avatar
    sounds like its time to send it to mendoncyclesmith.
    Quote Originally Posted by Duncan1104
    Yes, sounds like.
    But DAMN - I'm from Germany...
    Now you ^^
    reno
    try to PM him see if you can arrange something with him.
    Jup - I had contact with him - in another case. My TPC is from the United States
    I was at the postoffice, I thought about before sending the fork to him. It "just" around 45$ - that really sucks!
    Hope he will answer here!
    reno
    Feb 2005
    Basically, the fork needs to have it's races bumped up in thickness a hair. It may be out of square, or need a wholesale bump up all around. It can be made to go away to a more manageable extent, but it will also stiffen the feel, not badly, but worth noting. Particularly since a soft preload fork, such as yours, feels so, ummm, yummy.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Mendon is 100% as usual. You need to get the races replaced with thicker races.
    88aid has a branch in germany. Theycan 88Aid it for you and fix the problem.
    Hey Craig!
    Mhhh I really love the feel of my Lefty. But if you say it is possible to get it right - without migration - then this would be it.
    Whats you experience with migration? How much how often if the fork is set correct?
    Damn this looser working on my Lefty.
    He calls himself a specialist, watch out:
    http://www.fahrrad-kohl.de/
    I had to send the fork back to him because two of the bearings were to long, so there was space between the fork an the race.
    I can't understand how he didn't see this after assembling.
    And now the migration. Seems he is some kind of not good enought for a fork like the Lefty.
    In the german commnity, www.mtb-news.de everyone likes him.
    I hate to have trouble all the times. I want so ride!
    reno
    Quote Originally Posted by Brad
    Yes, I know. But I allready paid for this @ another shop.
    (One post over this one).
    I hate to waste money... but one thing is clear: Next time, only 88...
    Its me again!
    I got my fork back.
    The guy said he changed 2 races made them 0.02mm thicker.
    Got the fork back - kicked preload only to 2 turns.
    I'm 75kg and use red spring.
    I can't help myself out but the fork feels some kind of harsh over small bumps.
    How do I set rebound 100% correctly?
    I can hear the bearings work, is that all right?
    If I open the top cap, my Lefty doesnt move any more. I need to push it down. Before, it "compressed" ony from it own weight.
    Any idea to get this working better?
    Oh yes - we wrote about that - it has TPC+ from my Jake that got TPC now ^^
    thanks
    reno
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    I'd say ride it for a while to break it in.
    When the races and needle bearings are dis-assembled and re-greased it takes a while for the fork to feel plush again. (Depending on the grease that was used).
    The grease probably just needs to get worked a bit.
    If, after a couple weeks it still feels the same bring it back to the guy to fix it.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
