Results 1 to 2 of 2
    CODA Expert hubs
    Hi from Spain
    I want to replace the sealed bearings of my rear CODA Expert hub but I do not know how to removed them.
    Somebody could help me?
    Thanks in advance.
    Just tap the end of the spindle to knock out the bearing on the opposite side of the wheel, use a nylon head hammer, or other soft tool to avoid damage to the end of the alloy spindle. Would also be a good idea to remove the cassette before you start as I think the lockring will stop the bearing coming out.
    Make notes of what you remove from where as drive / non drive side parts are different sizes, also the spindle only fits one way, from the non drive side.
    Post again if you get stuck.
