Results 1 to 3 of 3
    Sep 2004
    Upset Coda Expert Brake replacements
    Hi, ive got a cannodale jeykll 900sx or sl (not sure) 2001 which i love to bits, but the coda expert brakes are crap as many of you know already. The rear caliper has started to leak and the brakes have never worked properly since having it and constantly need re-adjusting and bleeding. Ive tried to find a replacement caliper for it as its the cheapest option but have had no luck so gonna have to bite the bullet and replace at least the rear brake system. Not exactly experienced in the world of hydraulic brakes and wondered what hydraulic brakes would fit on the bike with the least hassle. Can i keep the rotors ive got on it and just replace the caliper, lines and lever? Thanks for any help
    Ridin' many miles...
    Reputation: EdZilla's Avatar
    Quote Originally Posted by ricardoo7
    I replaced my rear Coda Expert brake caliper and lever assembly with an Avid Mechanical and generic lever. It workes very well with the existing 4 bolt Coda rotor. Extremely well even.
    Sorry to hear about your Coda Expert brakes. I severed the hydraulic line in a high speed crash, replaced with the Avid and it worked fantistically, and is amazingly easy to adjust.
    So the answer to your question is: Avid mechanicals will drop right in to your existing settup even if you have 4 bolt Coda rotors.
    Ride dangerously. Take chances.
    Sep 2004
    Quote Originally Posted by EdZilla
    Cool thanks edzilla will look into it. Dont suppose you know of any hydraulic brake calipers to replace the coda expert??
  1. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  2. Deore disc brake with CODA discs?
    By nusbus in forum General Discussion
    Last Post: 07-09-2004, 06:42 AM
  3. Cannondale Coda Expert Disk Brakes
    By jpc111 in forum Brake Time
    Last Post: 06-30-2004, 07:55 PM
  4. Replacing Hydro line on Coda Expert Brakes
    By Edderd in forum Cannondale
    Last Post: 06-08-2004, 06:17 AM
  5. Coda Expert Disc brake
    By opticals in forum Weight Weenies
    Last Post: 04-05-2004, 08:54 PM
