Results 1 to 2 of 2
    Moven on
    Changed Spring Tonight
    I changed out my fork spring tonight on my 05 Prophet 600. My red one was way too soft, so I jumped to the brown. I got it from my LBS, and the numbers are what the fork manual calls for. The brown one was aprox 2" longer then the red one. I ended up putting it in, but it has a slight preload even with the adjusters all the way to the top.
    Dose this sound like it will be a problem?
    You got to ride um hard & put um away wet!!!
    That's a good question. I've noticed that the blue, red and black springs are different sizes also and have wondered about this too. I'm assuming since all of my springs are genuine Cannondale Lefty Max 140's they are designed this way.
