Results 1 to 14 of 14
Thread: Castle tool
    Castle tool
    I have a DD50 that I want to service and I need the castle tool "146/". I can't find them on-line. Any leads on one of these animals? Thanks.
    Okay. Can't seem to find an old castle tool, so I decided to make one. Bought a 7/8"- 3/8" drive Craftsman socket, drew some lines and got out the dremel tool. Three hours later, I have a tool. I couldn't wait to weld a handle on it, so I got out a big crescent wrench, used the notch as my "flat" and gave it a turn. Presto, my damper unscrewed. I am a happy camper. Now to find a new "spring" for my DD50.
    DD50 parts
    Here are pictures of the internals of my DD50, sans needle bearings/races. The elastomer spring is shot.
    Mar 2006
    A warning, be careful not to scratch the shaft. The castle tool has a plastic sleeve on the inside to prevent this.
    Any Cannondale dealer that's worth can get you any special tool you need. The best thing is that they're not that expensive.
    Reputation: amillmtb's Avatar
    Jun 2005
    Looks like a burned hot dog.
    The tool is cool though! I agree with Jiar, just make sure you dont scratch the shaft.
    Ha ha, yes, it does look like a hot dog. The one you left on the grill too long!
    I've seen the warnings about not scratching the shaft, Thanks!
    Reputation: jdr01930's Avatar
    Dude! You have seriously mad Dremel skilz!
    '15 Cannondale Trigger 27.5 Carbon 2
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    '08 F6 Lefty (son's)
    Thanks Man! It's very satisfying to "make" something and have it work.
    What did you use? The cut off wheel? I think if I attempted that I would have busted a few dozen of 'em!
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    Universal cycles has them for $35
    Quote Originally Posted by jdr01930
    I used up 3 cutoff disks. A woven fiber abrasive disk and part of a cylindrical stone. Also use a small hand file to square up the "pins".
    Probably going to do some more clean up on it before welding on the crossbar.
    Quote Originally Posted by JasperIN
    I saw that one and I don't think it would fit the older Headshoks. On the older Headshocks, the top cap does not come off the shaft (at least from what I can see). The socket cost me less that 4 bucks.
    Finally done. Welded a flat piece of steel to the socket and did some more grinding. Need to crank up the current on the welder and practice more.
    The final fit. Just in case you are wondering how it fit. I got lucky.
