Results 1 to 5 of 5
    Cannot remove steer tube from head tube on Flash 2011
    Hi All,
    Currently running a MCFK carbon steer tube on my 2011 Flash with a Lefty DLR fork. I have tried to remove the steer tube (in order to remove the fork from the frame), but I am unable to get it out. Seems to have seized up with the bearings in the head tune. Any good ideas how to get it out without destroying the MCFK steer tube?
    Thank you
    seismic
    Feb 2005
    No experience with that steerer, but assuming it was made to the same dims as an OEM steerer, get one of these if you don't already have one, apply some good penetrating lube if it doesn't just pop at that point, and beat the ever loving snot out of it till it relents.
    No other way....
    Cannondale Ernie Lefty Steerer Tube Install Tool - KT020/ - CannondaleExperts.com
    Edit: All this assumes you loosened the pinch bolts on the fork before removal attempts.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    well, I get a bit concerned when you say that I should beat the hell out of it. Did I mention that the steer tube is made of carbon? Not sure it will stand up to many hard hits.
    Feb 2005
    That's what the tool is for. You hit it, and since it fits nicely into the steerer, you avoid any damage. Again, assuming the maker of said steerer, used the same dimensions as an OEM version.
    If there's a poor or non fit, then you will have to take it from there, creatively.
    That help?
    - FrostyStruthers
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    You can also use a piece of PVC pipe of the same diameter as that tool. Worked for me.
    Quote Originally Posted by MendonCycleSmith View Post
    No other way....
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Steer/head tube Size
    By shjacobsen in forum Shocks and Suspension
    Last Post: 06-10-2013, 05:02 PM
  3. Tapered Steer Tube vs Straight Steer Tube
    By maw77712 in forum General Discussion
    Last Post: 05-24-2013, 10:28 AM
  4. head tube length and steer tube length
    By freeriderB in forum All Mountain
    Last Post: 02-23-2013, 05:09 AM
  5. Replies: 5
    Last Post: 04-08-2012, 10:28 AM
