Results 1 to 5 of 5
    Cannondale XC3 HeadShok, 25.4 mm question
    I have a 06' Scalpel with a Cannondale XC3 HeadShok, 25.4 mm stem. I am wondering what is 25.4 mm a measurement of? I am thinking about switching to a lighter stem, and want to figure out what size/measurement should I be looking for.
    I am also wondering if I am restricted to using Cannondale Stems only, or will other companies stems fit?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    25.4 is the diameter of the handlebar at the center. There are 25.4 or 31.8 bars. Stem choices are limited, you need a Headshok/Lefty specific stem since the steerers are slightly bigger than 1.5" steerers and much bigger than the conventional 1.125" steerers. To my knowledge, brands that make Headshok/Lefty stems are Cannondale, Hope, Kore, Woodman and Syntace and their VRO stem-bar combos... Roel Paulissen has been spotted with a carbon FRM stem on his Lefty recently so maybe they have some stems too, or will release some eventually.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Mar 2006
    And why he isn't using the integrated stem/steerer tube?
    LA CHÈVRE
    Who knows but if I had to guess, it must be lighter. The FRM stem has a nice reputation, apparently one the lightest carbon stem around.
    LA CHÈVRE
    Yep, add FRM to the list. 130 grams with Ti bolts, I don't know how light that is compared with other options...
    Worth noting is that they also make Lefty hubs and wheelsets, including a tubular wheelset...
