Results 1 to 7 of 7
    Cannondale V-Tech Grips, how do i remove them?
    Hi people a dumb question, I decided to upgrade my grips and the thought had come to me that i have never removed grips before; the Cannondale V-Tech Grips were on my rush 2000 since I first bought the bike but now aren't comfortable anymore, I wanna remove them but not destroy them, might use them as spare or put it on another bike as they are still in pretty good condition, anyone have any advice on how to non-destructively remove them? thanks!
    If you have access to a air compressor you can usually blow em' right off without causing any harm at all. Just place the nozzle underneath the leading edge (closest to your lever mounts) and pull the trigger.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    If you don't have a compressor just slide something that will not scratch your handlebar (like a plastic knife) underneath the grip, squirt some windex in, pull the knife out, pull and twist and they'll pop right off.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Awesome, great suggestions guys! thanks Unfortunately don't have an air compressor to blow them off which is one i'd rather try ha So i'll go with cdalemaniac's suggestion heh Thanks!
    Quote Originally Posted by Nocturnalnature View Post
    Be careful doing this if your compressor doesn't have a rubberized tip on the blower attachment! I scratched the heck out of my wife's bars by doing this once, because it's hard to get the grip "peeled away" from the bar enough to get the tip inside.
    If your bike has bar-ends underneath the grips, I find that the best (and quickest!) way to get the grips off is to stick the blower's tip right into that little hole at the end of the grip, and then the grip just flies off!
    Drop by your local pharmacy to get a syringe and needle (thickest so they don't snap so easily). Fill it up with water, prep the needle, insert into grip at the angle most parallel to your bars as you're comfortable with. When you feel that the needle is all the way through the grip and touching your handlebars, inject water. Grip would slide nicely out.
    Thanks guys for the input, i'm sure other people will find this useful!
    I actually used dishsoap in a spray bottle and used popsicle sticks to pry an opening and sprayed it in, worked it around the inside of the grips and they just wiggled off
  1. How to remove handlebar grips
    By edesros168 in forum General Discussion
    Last Post: 04-03-2012, 03:59 AM
  2. easy way to remove grips ?
    By max_29 in forum General Discussion
    Last Post: 03-17-2009, 01:56 PM
  3. Any tricks to remove grips?
    By aaron04 in forum General Discussion
    Last Post: 06-16-2008, 02:46 PM
  4. Remove Grips without tearing them up
    By gradster in forum Tooltime
    Last Post: 07-19-2006, 01:13 PM
  5. Help me remove some grips!!
    By Otter in forum Turner
    Last Post: 10-29-2005, 12:59 PM
