Results 1 to 9 of 9
    Jun 2013
    Cannondale Trail SL Cable Concern
    I am building a 1 x 10 out of a Trail SS and on my other bikes the shifter cable is covered on the bottom. I was thinking of running housing over it and wondering if that is necessary and if anyone is having problems with the exposed cable? I imagine a rock popping up would damage it fairly easy.
    Jun 2013
    Any thoughts?
    Jun 2013
    WOW... shocked no comments I guess I will leave it as is or put housing on the bottom.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The cable wont be damaged by rocks unless you grind on it a long distance... but that would probably also grind through a housing... and if that much damage was to happen, your cable wont be your main concern.
    Full housing can help prevent dirt working it's way inside the rear housing loop though, making the need to replace the cable coming later into the bike's life. But that depends of the conditions you ride in.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    No it wont be necessary.. cables are more durable than that
    Jun 2013
    Thanks for the reply, I was hoping it would be okay.
    May 2013
    like other people said, if anything got in there, you'd have scratched frame, crank damage maybe chain damage or derailleur damage. Of all those things the cable and cable housing is easiest to replace.
    Noobish
    2013 Cannondale Trail 29er 1
    1990ish Specialized Hardrock
    Reputation: crazee horse's Avatar
    Sep 2012
    mine is crud city, no problems mate.
    Jun 2013
    Sounds good. I am taking her out this weekend for the first ride as a geared bike.
  1. please delete
    By discohospital in forum Cannondale
    Last Post: 07-20-2013, 01:54 AM
  2. Replies: 1
    Last Post: 04-16-2013, 06:20 AM
  3. 2011 cannondale trail sl3 vs 2012 cannondale trail 5
    By idon'tlikepink in forum Beginner's Corner
    Last Post: 08-22-2012, 07:56 AM
  4. Cannondale Trail series cable routing?
    By Sean831 in forum Passion
    Last Post: 04-13-2012, 08:08 AM
  5. Replies: 1
    Last Post: 06-08-2011, 04:43 AM
